AutoCad 2004 to SW 2004
Hows it going? Trying to convert AutoCad 2004 solids to SW2004 using an .SAT file.  It all works well, except it converts it from inches to milimeters. Not changing the amount of the length number just the unit. Example.  Drew something 80 inches in Autocad. Comes into SW as 80 mm.  Any ideas?
Greg
RE: AutoCad 2004 to SW 2004
What are settings in default part template for SW?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
check your export options when you do the file save as
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
the default part template in SW is correct......In Autocad there is no options when you export. We just figured out Autocad must have left something out because a guy that works here has Autocad 2002 and it prompts him how to export it.......
I tried it here with ACAD 06, it did not prompt me. My settings in ACAD were in inches. I checked the model in SW after importing the .sat, settings were in inches.
Chris
AutoCAD 06
thanks for trying Chris..........Ill have to keep looking into it.
Greg
