Help needed on rotating solid feature
Hi. I have created a solid using extrusion. I needed to rotate the solid around z-axis 45 degree. I can seemed to find any command in Solidworks 2004 that allow me to rotate the created solid. I hope someone know how to do it.
RE: Help needed on rotating solid feature
If within an assembly file, create your mates such that you mate one plane at 45 degrees from another.
That's my best guess as to what you mean.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
advised. I was hoping to rotate the solid part along z-axis
directly.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
