Z-level_follow_cavity
     we have just switched from NX3 to NX4.In NX4 I couldn't find Z-level_follow_cavity.It was active in NX3.NX4 only got simple Z-level Cavity milling.If anybody knows about this please give me some information.
RE: Z-level_follow_cavity
Its gone :) In the documentation it says:
"In Mill_Contour, the ZLEVEL_FOLLOW_CAVITY operation has been removed. The CAVITY_MILL operation provides the same functionality. If you require the old operation for special applications, you can restore it by changing the template setting in the template parts."
-Derek
Thanks Derek!  I will give a try.
