Weld of Bolt
Weld of Bolt
Weld of Bolt
I have two steel beams that will be joined in a T-shaped geometry.  I have completed the load analysis, but I have little experience is in the appropriate method for joining of these memebers.  I have a fairly good reference text for designing a bolted connection, but I am largly ignorant when it comes to desiging a welded connection.  To envision loading, imagine the singular lower portion of the T to be 10" and cantileverd out in space.  The upper portion of the T is 40" and will have an equal load pulling down on each end, so I will need to transfer the shear and moment loads though the connection.  We are talking about a large structure carrying around 2.5 tons on each arm of the T.
Could someone offer some advice and perhaps point me to a good reference for understanding the proper design considerations of welded and/or bolted joints?
Thanks!
RE: Weld of Bolt
Follow the thread below to the web site and download the book titled "Guide to Design Criteria for Bolted and Riveted Joints";
thread725-143788
RE: Weld of Bolt
If you want to learn about welded connections, start with Omer Blodgett's book "Design of welded structures" or "Design of Weldments".  You can get them off of the Lincoln Electric website, and they are very economical.
RE: Weld of Bolt
Thanks guys!
I will check out the references listed!
