ASME B16.20 Hydrotest Pressure
Hello All, as I recall it is 1.5 x 100 deg. F rating rounded to next higher 25 psi. Does this sound correct?
Mike
RE: ASME B16.20 Hydrotest Pressure
SnTMan;
What is it that you need? You don't have a copy of this Standard? ASME B16.20 is very clear on pressure class rating and gasket bore size, etc.
Right, did not have it handy and was working from memory.
Mike
Don't work from memory.
Sorry, I meant B16.5. One of those days.
Mike
