Create a helix along path
Is there anyway to do a helix along path, like a electrical resistance?
RE: Create a helix along path
... a sweep of a circular cross section along a helix curve would fit your needs ...?
'Ability is 10% inspiration and 90% perspiration.'
using the revolve option you will be able to do it. You choose your section, and then you click options and revolve through "translation along axis"
This shlould work
