utility transformer
utility transformer
utility transformer
While working as an intern, I worked with a senior engineer designing a few residential services. The services are 250 amp, but the poco mounts a 25KVA transformer on the pole. What criterias do the poco engineers use to size thier transformers?
thank you all.
RE: utility transformer
Experience with typical residential loadings and occasional transformer overloads.
yours
