Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Where have you been all my life! I found the answer I needed in seconds..."
Geography
waldospe (Chemical)
29 May 06 15:38
I'm using a metal-cutting bandsaw to cut thin slices of 4.5" round 6061 aluminum stock.  What is the best blade choice for a smooth face and this thick of stock?
Helpful Member!  ornerynorsk (Industrial)
31 May 06 11:45
Use as coarse of a tooth as you can find, lots of coolant, and a very consistant feed.  About 200-250 fpm blade speed should do nicely for a high-speed blade.  A finer tooth will only gum up the kerf and leave lots of saw marks, you want those chips OUT of the cut asap.
Close Box
Join Eng-Tips® Today!
Join Us             Close
