Which is more accurate,powergraph on or off?
Hi,everyone:
The result is different when powergraph being turned on and off.I wonder which is more accurate?
RE: Which is more accurate,powergraph on or off?
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
Drej's explanation is very accurate. I'd only add a strictly personal point of view on how taking best advantage of the way Powergraphics works:
- generally don't rely blindly on the results you "see" whenever powergraphics ON and OFF give very different results: in these cases, the mesh density is not adequate locally; so, either refine locally, or "invent" some hand-made post-processing methods (best-fits, corrections based upon analytical Stress Concentration formulae, etc...)
- powergraphics ON will amplify surface-effect based S.C., while by turning it OFF you will decrease their weight (in our factory, it's a method we intentionally use for that reason because we know it to be more realistic when compared to experimental results. In our case, the best correlation "numeric-vs-experimental" is achieved with "nodal" results with Powergraphics off (for all the "routine" works; of course when we set up "exotic" verification models, we can't rely on this and further investigation is necessary), but in your case it may or may not be the same. You have 5 possibilities (integration points results, elem results w/ Power ON, elem w/ Power OFF, nodal w/ Power ON and nodal w/ Power OFF), so be careful...
- there are cases in which the S.C. is due to non-removable geometric reasons (triple corner, etc...), so that even increasing mesh density will not really help. In these cases, PowerG/ON will worsen the situation...
