Turner criterion
Turner criterion
Does anyone have a spreadsheet that uses the Turner criterion to calculate minimum gas flow rate for lifting water?
Thanks.
Thanks.
RE: Turner criterion
You need to go to www.spe.org and go to their e-library. Search for R.G. Turner (I think his JPT article was 1967 or so). Print the document, READ IT, understand the limitations of the calculations, then spend 15 minutes building a spreadsheet. Any other approach is just asking to apply the calculations in a pressure/temperature region that is not appropriate.
David
Thanks, I'll spend the time and write my own spreadsheet or C# program.
KC
