Split Sleeve Cold Working
A few years ago there were reports floating around industry about microcracks forming in 7050 series plate in the ST direction when Split Sleeve Coldworking was applied to a hole.
Does anyone know these report numbers?
Did SAE or AIAA have similar reports?
Does anyone else remember this? Everytime I bring this up to someone I get a mystified look.
RE: Split Sleeve Cold Working
Tech Suport
1864 4th street
FTE1
AFRL/XPTT
WPFB, OH 45433
1-800-203-6451
Stache
White rabbit was asking about hole cold working using the split-sleeve-mandrel system [Ah-la Fatugue Technology Inc].
I think You are refering to installation of fastener-sleeves [MIL-DTL-85068/*] for oversize-hole repair using nominal size fasteners.
Boeing has significant restriction on FTI split-sleeve hole cold working [SSCX] in the ST orientation. Reason is as follows...
Ref MMPDS or MIL-HDBK-5 data for 7050 alloy allowables. In the ST orientation "e" can vary from ~10% to ~50% of "e" in the L orientation which are not all that high (~8%-to-12%). This is BAD from the perspective that most cold working requires 3%-to-6% hole expansion just to gain 1%-3% residual (compressive) strain (~increase in hole dia) after CX. Obviously 4% strain on a grain orientation with only 3% strain [at failure], is guaranteed to split (crack) the part on the suseptible grain orientation.... or induce such high residual stresses that it will split (crack) in-service.
Note: Boeing stress engineers are required to use a substantial "knock-down factor" for certain ST calculations involving fasteners [proprietary].
Regards, Wil Taylor
