structural adhesive
structural adhesive
Hi everybody!
I am looking for a structural adhesive tape but I prefer a glue (because I do not want thickness) to bond aluminium (with passivation or anodization treatment) and steel. The bond have to resist to sea salt fog, and temperature between -100°C +100°C.
I will appreciate any suggestions!
Thank you
Thank you
RE: structural adhesive
If you apply a zero thickness of adhesive between two non-porus parts you get zero bonding.
Does the steel have any protection such as paint or plating?
If it does your bond is only going to be as good as that material.
As well as the companies Mint Julep mentioned, check with Dexter/Hysol they have some good structural adhesives.
B.E.
I will have a look on this adhesive.
Greets
