Fillet weld leg length
Is there any requirement for the size of fillet weld leg length in accoeding to standard or code?
RE: Fillet weld leg length
AWS D1.1 has minimum fillet weld sizes based on the thickness of material.  It also specifies that if a fillet weld size is not called out on the drawings, that the minimum fillet weld size applies.
Thanks GRoberts.
How about the maximum leg length? i have read some post and the information from the internet talking about that , but i still can't be sure that the maximum value of that.
For AISC and AWS codes, there is a maximum weld size in lap joints.  If the material is >= 20 mm (or 3/4"), the fillet weld must be at least 2 mm (or 1/16") smaller than the material thickness.  This is for inspection purposes--if the weld comes all the way up to the edge of the material, it can melt away the edge so that what looks like a fillet weld that is the same size as the full material thickness will actually be undersized.
Hg
Eng-Tips policies:  FAQ731-376
