heat transfered on liquid in tank only by conduction
if i claculate heat transfer through insulation and all materials of tank,how can i calculate heat transfered to liquid in tank?,because tank is not full and there is some level of liquid in there and above that is empty space,for example air and heat coming from outside come from all area of tank
i need to connect level of liquid with amount of heat given to that liquid ,because it's not the same i have full tank or level near empty for a same amount of heat coming from outside
tnx
tnx
RE: heat transfered on liquid in tank only by conduction
corus
