tuner location
tuner location
I can see very informative post for intake tuning on forum list & just follow up with one of the valuable reply by Rob 45 @ tuner location- "one can calculate the position of tuner" -
In othere words how does one can analytically calculate the location of quarter wave/helmoltz using hand calculation? Is it possible to calculate without dyno as the supplier would have limited access.
SAE paper/proper direciton would be appreciated
RE: tuner location
But to be honest I've found that calculations only get you so far with air intakes.
Cheers
Greg Locock
RE: tuner location
But, would like to follow other things as well related to intake systems & hope if i get some confirmation:
Generally, quarter wave resonator design to fix the particular frequency. Just,consider the case like 250 hz is problem , hence the wavelength = 1170/250 so the length of the tube would be 14 inch.
(1) So does it mean that tuning frequency of the quarter wave would be 1000 hz? (As everybody know, frequency = sound speed / wavelentgh)
(2) If not what would be tuning frequency? (definitely the one you wanted to hear)
(2) The wave travel after half the wavelength will collide with the main wave with 180 out of phase but it would be in phase after the full wavelength & would be the superposition at crest instead of interference.
Doesn't it mean that qurter wave would decrease noise at half wavelength travel but will increase at full wavelength travel? Or,I am going in wrong direction?(tried to draw waves on paper & question did )
RE: tuner location
"I would like to correct my self as the problem frequency (like 250 hz) is the one at side branch or helmoltz is tuned so when the problem frequency generates than resonator will reflect the same frequency out of phase & cance the noise."
I will really appreciate if Greglocock/Rob 45 or similar expert can confirm above statement?
RE: tuner location
Cheers
Greg Locock
RE: tuner location
Just for reference a speaker is a tuned enclosure comprising one or more drivers - not the/a driver itself.
