How to apply relationship between dimension?
Hi. I am quite new with solidworks. I am using solidworks 2004 and have created a cube with a cole in the middle.
I have dimensioned the centre of the hole to the right and left edges of the cube to be the same. Is it possible to put a relationship between the two dimension i.e. the distance from the centre of the hole to the left and right edges of the cube to be equal so that when I make changes the cube, the hole stays in the middle i.e. with the same distance from centre of hole to left edge and to right edge.
Thank you.
Thank you.
RE: How to apply relationship between dimension?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
ratio (not necessary in the middle) that I want.
Right Mouse Button
Chris
AutoCAD 06
Check into Design Tables. It may be what you need.
Chris
AutoCAD 06
