Completing a task should set the actual finish date
When completing a task project does is not changing the actual finish date to the date that I completed the task. According the reading I have done this should be defaulted?
RE: Completing a task should set the actual finish date
When completing a task, you enter the actual finish date.
How else are you "completing" the task? Any other approach will complete the task on the planned finish date.
TTFN
To update the progress of a project, I click on the "View" drop down menu, move curser down to "Table: ____ >" The underscore represents the view you are currently looking at. Me, I often go back and forth between Table: Entry and Table: Tracking. Then move the cursor over to the next drop down menu, and select "Tracking". Once this is done, the table headings will change from "Start/Finish" to " Act. Start/Act. Finish". NOW is when I enter in the completion dates.
My management likes to see the Entry form of the table, so they can see the projected finish dates of the project. I do all of my updating in the Tracking table form.
