visibility of objects
i read some where that there is a setting for objects in which you can turn on and off via lsp or vba any one have any ideas thanks
if everyone helps everybody the world will be a better place
RE: visibility of objects
Yes you can set an entity's group code 60 to 1 to make it invisible.  0 or absent and it's visible.  Since you're an old-time lisper (at this forum) you can probably take it from there.
ResourceCAD has a free download to modify the visibility of blocks if you're interested
www.resourcecad.com and goto the downloads section
This sets the property to invisible. Remember though, to make it visible, you have to do that back through code..
(defun MAKE_INVISIBLE()
  (vl-load-com)
  (setq ENT (car (entsel)))
  (setq VLENT (vlax-ename->vla-object ENT))
  (vla-put-visible VLENT :vlax-false)
"Everybody is ignorant, only on different subjects." — Will Rogers
ok so i found a lisp already done that does this intead of having to build it my self :) but the thing is how can i make an object invisible but prints ???any ideas thaks
if that is what you are after, why didn't you ask that question in the first place ? The question you originally asked is completely different
yea but i also like to know how to get to the answer as i ask questions i some time find the answer by accedent plus i hope that others learn from what i show as well :)
