COB used for flashing pins
Does anyone know what the cob (chip-on-board) is on a flashing led novelty pin? Or a one chip solution to flashing an IR led? Needs to be a very small package, space is very limited.
RE: COB used for flashing pins
First thing I would try would be to get one of your novelty pins and tear off the coating then look at the chip with a microscope. Often they have logos or part numbers on them.
Keith Cress
Found it??? A quick google using "Melody IC" (since the companies that make these devices probably also do blinking IC die) found www.mosdesign.tw who list "LED BLINKING" as a product category. You might look here or continue my google search.
http://www.uoguelph.ca/~antoon/circ/ledflash.htm
Very nice sleuthing Comcokid..
Keith Cress
Looking at the specs of a blinking LED indicates that it may work.
http://www.farnell.com/datasheets/72811.pdf
