Rate of Change Alarm on Automated Movement
One of the pieces of news that came out of Buncefield explosion was that the level indicator was stuck during the movement (filling task). This was of course in addition to the HHLL switch not working.
I would expect that there should have also been a rate of change alarm (in this case, lack of rate of change) on an automated movement, or is that just me?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Rate of Change Alarm on Automated Movement
Hi Ashereng;
Do you have a link to the Buncefield explosion so we can get some background?
respectfully
Ashereng,
I agree with a rate-or-change alarm.
We have done this for many years now.  If the tank level does not change X amount in X time when we are filling, or emptying, there is an alarm.
In addition, if a tank level is changing when we are not filling/emptying the tank, there is an alarm.
______________________________________________________________________________
This is normally the space where people post something insightful.
