Am I getting stuck with a career I don't want?
I recently graduated college and am worried that I am going down the wrong path in terms of my career. I received my BSME during May 2005, and I took the FE for the first time approximately 3 weeks before my graduation and passed the exam with ease. My EIT certification came in the mail during June 2005.
Six months passed between the time of my graduation and my first interview. I did not think getting that first engineering job was going to take so long. I received the first job I interviewed for and have been working there 6 months. I am working as a quality inspector for a company in the trucking industry. The job itself pays very well, however I in no way, shape, or form use my degree. Most of the inspectors I work with are diesel mechanics not engineers and many of the so called engineers above me don't have engineering degrees.
During my time at college thermodynamics, heat & mass transfer, fluids, and thermal component design were my favorite courses. I would really like to get a job in the power generation industry but there are many other fields I would still be more than happy to work in. I have been sending out my resume and applying for entry level positions with no response other then the occasional, "you have no relevant internship experience" I am afraid that I am digging myself into a hole. The experience I am currently receiving is not relevant to any job I want. I could stay where I am and advance to a better position but I would still have a job I don't like. I really don't want to work in any QA/QC/QE type of position.
What can I do? Should I go back to school and get my masters? If I was enrolled full time I could get a co-op position with a company that is in a field that interest me, then I might stand a better chance.
RE: Am I getting stuck with a career I don't want?
First thing, everyone seems to want to steal trained engineers from someone else and no one wants to train engineers. So I would suggest enrolling in some professional courses that deal with the latest buzzwords in the industry you are targeting. As long as they are coming from a respectable university, they are pretty good resume candy until you get actual experience. Even if its entry level stuff.
Another trick, would be to go to a professional resume builder and pay to have your resume looked at. Or talk to a recruiter/headhunter about your resume for tips. Weird story that happened to me, is that I had two recruiters talk to me about simply reformatting my resume, since they both said the same things independantly, I took their advice. About a week later, with the same information on my resume but in a different format, I got an interview and an offer where they exceeded what I was asking. And my resume didnt look bad, either. Its just the college service I took it to, really didnt do a good job I guess.
Third trick, and one which really seems to impress people, is that you CAN use elements of your education even if your position doesnt require it. Set them up as personal professional projects to do that will benefit your company AND give you experience where you want to go. I had two jobs previous to my new one, and while they were well outside of where I wanted to go, I voluntarily setup, performed, and completed various projects that I liked that I gave my companies an edge, gave me experience where I want to go, and could be put on a resume. After all, I had an open mind to try out some oblique and specialized areas in my field, but was still loyal enough to go above my normal requirements to benefit my company conventionally, is exactly the impression I sought to give in interviews. Those types of deals really seem to work out well. Made for a great talking point in an interview. Additionally, if your experimental project was really beneficial you may convince your current employers to put a further emphasis on a direction that you want.
But above all, keep your chin up and good luck, its not so bad, I have been there, as what you have happened happened to me as well.
Welcome to the world outside of college.
To build on what tgeorge says, that FIRST JOB is really important. If it's an "easy" job, then be GREAT at it. Doors will open.
Here's how to deal with this: "you have no relevant internship experience"
a) Screw that. Interns are there to make photocopies and coffee.
b) Get a master's degree and concentrate in the area you like. Do it at night while you're working. With the MS in hand and a couple of years' worth of genuine work experience, the internship crack won't make sense.
Don't expect the first job to be the one you really want. It usually isn't. Put in your time, and expend the effort to do your job to the best of your ability. You won't be there forever. When it starts to get to you it is best to remind yourself that you will eventually find something better. Putting together a plan is essential. Earning a Master's degree is a worthwhile pursuit, and I recommend that you get your employer to pay for part of it if they have such a program in place. Prepare yourself for the next job by learning everything that you can from this first one. As you earn your degree, start looking around for a job that is better suited for your interests and abilities. By that time you will have two or more years of work experience under your belt, and some good references to share with your potential new employer. Don't make a decision to quit based on the strength of emotions - it usually bites you in the end. And I learned this the hard way.
Maui
On the other hand, your current employer has hundreds, maybe thousands, of units that convert fuel to work on a smaller scale every day. In aggregate, they consume a lot of fuel, so your employer is definitely interested in even tiny improvements in efficiency or downtime or service life or unit cost or ... anything. Better, the risk of damaging or disabling a single unit is small, relative to the cost of trashing a single unit in a powerplant. The units are mobile, so you don't necessarily have to travel to them, and you don't need to deal with Homeland Security just to get at them. They're full of flowing fluids and moving parts and transferring heat and ... well, all kinds of stuff that interests most mechanical engineers.
Power generation guys would _kill_ for your job.
Make lemonade.
Mike Halloran
Pembroke Pines, FL, USA
If not, as someone suggested, use some of your other engineering skills to improve things around the place. Design worksop equipment or test fixtures. Do it thoroughly. Turn yourself into the go-to man for technical advice.
If none of that works, apply for the same job as you are doing now with a company that DOES have engineers doing what you want to do, and after a couple of years apply for an internal transfer. You'll be a known quantity by then, and should have prepared your ground carefully.
I wouldn't fret overmuch about not doing a 'real' engineering job at this stage in your career, you are learning things that need to be learnt.
Cheers
Greg Locock
tgeorge
I have had several people help me with my resume, this helped me get the job with my current employer. The personal professional projects idea is very interesting and was an option I had previously not given consideration. However I will now take a closer look at using such material to attract employers.
Heckler and Maui
One thing I will not do is quit because it is not my ideal job. I will not leave until I find something else. I don't hate going in to work every day, I would just prefer working elsewhere. I accepted the job because it paid well, and it was better than nothing at all.
MikeHalloran
There are a few positions with my current employer I would like, the only problem is they are all 3000 miles away. I work in a manufacturing facility, all the design work is done elsewhere and many of the components used are bought from and designed by outside suppliers, such as Cat and Cummins engines, Bendix air equipment, Dana diffs, Fuller and Meritor transmissions etc... As for working in a union environment the plant I am currently working at is a union plant, and I absolutely hate the UAW. There are many reasons why but I don't feel this is the appropriate place to discuss such matters.
GregLocock
I like the idea of designing workshop equipment or test fixtures, I had thought of doing this is well but the problem I along with other inspectors have heavily encountered is our input is considered useless no matter how relevant it may be. I would like to elaborate further on this matter but I feel it would be unethical to due such as it would end up covering confidential information.
From the subjects you listed are being your favourites at college, you might look into Performance Engineering for the powergen industry. Quite a niche market, and good ones are worth their weight in gold. You'll find a lot of the work is theoretical, sometimes leading to great ideas which no one will support, and you will be chasing improvements where 0.1% is a massive gain. On the plus side, you'll have a rewarding job where you can have a huge financial impact, a lot of autonomy, and the chance to work with experts from the electrical and mechanical disciplines, financial, and commercial.
I don't suffer from insanity. I enjoy it...
Otherwise, being a facilities engineer for a large power generation facility or large plant facility could be more beneficial to learning about your interests.
-The future's so bright I gotta wear shades!
All of them are easier to deal with once they realize that you will not lie to them, will not betray their confidences, and will not do anything to directly cut into their overtime. They don't mind you making a task of theirs easier, so long as you don't make it noticeably quicker.
I know what you mean about the Home Office. I went a few rounds with brand C about a bracket design that strongly impacted my product. It was only used to support the engine from an overhead conveyor during manufacture, but because it was 'structural', no one dared even _request_ a simple design change. That said, the manufacturing guys had some flexibility wrt to manufacturing fixtures and tools that weren't actually part of the product.
There _has_ to be something at your location that can keep you amused. Look around for small problems you can solve.
Mike Halloran
Once upon a time, just out of high school, I was working for a short period in a truly horrible department, where my job was basically clerical, modifying numbers in build sheets and entering the new total. I was bored witless.
So, instead of whingeing about it, I wrote a paper describing how the process ought to be done (using those damn new-fangled personal computers). They loved it. At the end of the job I got a stellar evaluation and they asked for me to come back and help implement it. No thanks, but hey, I needed all the good evaluations I could at that point in my career.
I find it difficult to believe that any job has no aspects that an engineer could not improve.
Cheers
Greg Locock
India and China are building masses of power stations. The technology may come from the UK, Europe or Japan.
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
Why not come down to the land of downunder where theres heaps of jobs available, nice weather at Queensland, nice tanned women, watch the rugby league every weekend and the people are friendly. The fishing is great too! Brisbane is your place- im sure you can find a job here.
If youre a thinking of going back to uni for your masters. Do it at the University of Canterbury, Christchurch NZ. Vgood uni, NZ is beautiful and you get good exposure to the lands down under!!
