fiber optic temperature monitoring
to thread238-138610
I am currently searching fro a possibility to monitor temperature on circuit breaker conductors (under tension). I would really be interested to get some more information about the possibility to measure the temperature with this fiber optic technology.
RE: fiber optic temperature monitoring
Enclose is a link for fiber optic distributed temperature sensing (DTS)
   http://www.sensa.org/userDocs/IS-PWR-Iss05-BASE_web.pdf
I am not sure if this technology is cost effective for the type of application described in your post. A possible alternative is using probe or infrared cameras to detect high temperatures.
Everything depends what you would like to measure. If this is a discrete measurement you can use point type fiber optic probes:
http://www.fiso.com/index.php?module=CMS&func=view&id=105
http://www.luxtron.com/product/utility/fiber.html
If you measure something like long cable or surface you may want to use distributed type devices mentioned above but check also:
http://www.ehvpower.com/OTS_monitoring.htm
http://www.sensortran.com/ApplicationElectric.html
http://www.lios-tech.com/Applications/Electric+Power+Sector/Application%3a+Power+Cable+and+Overhead+Line+Monitoring
There are also others.
