Boundaries vs.Extract
I am new in this forum and may be my ENGLISH is not as good as
yours, anyway i will try to explain my indecision
about creating curves.
If i need boundaries curves there is the appropriate Command
but personally I prefer use the EXTRACT command.
I TESTED both command during REPLACE scenario.
The rusults were ...impossible to say BOUNDARIES IS BETTER THAN
EXTRACT and viceversa.
so I wish to know if anyone can help me to understand which is
the command MORE STABILE during the REPLACE and UPDATE PHASE.
I am using V5R16
thank for all
I am using V5R16
thank for all
RE: Boundaries vs.Extract
I use the boundary function only when I'm trying to find openings or gaps in Join surfaces.
I've never slowed down long enough to explore the differences. Hopefully more of you will discuss this, so I can learn...
CAD design engineering services - Catia V4, Catia V5, and CAD Translation. Catia V5 resources - CATBlog.
To find openings or gaps in Join surfaces use "Connect Checker" and select "Internal edges"
I do the same thing as "flangewiper". I use "Boundary" to get edges, and use "Extract" to get surfaces and faces.
I wish to share some picture taken by my scenario
to show you what happened when I built a point
on the EXTRACTED curve and replaced the surface.
now the problem is:
HOW CAN SHOW YOU MY PICS??
GIUMEL
http://www.eng-tips.com/viewthread.cfm?qid=127497
