Help needed with circuit
I need some help regarding a circuit operation. I will try to describe it as best I can.
Input is a 1:1 pulse train of 200-10Khz. This is fed into one input of a NOR gate. Output goes through a 10nF cap to a pullup resistor of 10K. This also goes through a 10K resistor to another NOR (other inout is tied to gnd). Output is fed back to first NOR gate. I dont understand the purpose of the feedback. Any help would be greatly appreciated.
_|_pull up
_____ |_| _____ _____
input___) nor\0___||__|___|10k |____)nor \0____output
___)____/ || |____| __)____/ |
| 10nf |gnd |
|__________________________________________|
CODE
_|_pull up
| 10nf |gnd |
RE: Help needed with circuit
Gunnar Englund
www.gke.org
so basically it generates a 100us pulse at 200-10Khz depending on input frequency?
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
