Crack with ABAQUS/CAE
Which steps are implied to generate a seam and crack with ABAQUS 6.5-1 CAE?
udar
RE: Crack with ABAQUS/CAE
The steps that lead you to a training course.
Thanks, john
udar
Look in the ABAQUS example problems manual - section 1.4 "Fracture and Damage"
Seek and ye shall find....
Finally I have turn out right to generate a model with crack with CAE. For a suitable J value ( and also T stress, etc.) is need to rafine the mesh in front of the crack.
The way is to work on each regions of surface partition near the crack front ?
regards,
udar
I'm working on a C(T) model using ABAQUS/CAE and I've defined a crack following the instructions present in this brief http://www.abaqus.com/solutions/tb_pdf/TB-04-FMCAE-1.pdf.
I'm using a half-3D model (quarter actually due to simmetry).
I have a problem with the mesh at the crack tip. It's written that after creating the crack and singularity (I don't have the seam because of half-model) ABAQUS/CAE creates automatically collapsed elements with correct connectivity definitions. It doesn't happen! Do I miss anything?
Thanks in advance.
Chris
