PhotoWorks Materials.
Hi everyone,
I was wondering if anyone ever found a site with PhotoWorks materials. I know there are a lot of sites with textures, and a lot with physical description of materials (with mass, stretch factors etc.) and also a couple of threads on the subject.
However, I am looking for PhotoWorks Materials. Or at least a site that lists the visual properties of material (such as base color, reflection, etc) that I could enter in PhotoWorks.
P.S. On a side note, Thank you for all the help around here. Even though I don't post much, I often use the forums to solve problems. CorBlimeyLimey ctopher Bradley SBaugh are a couple of names that come to mind. Keep up the great work!
RE: PhotoWorks Materials.
http://
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Chris
AutoCAD 06
One thing that helps in figuring out materials is establishing a good scene to stabilize some of the variables before trying loads of settings in materials. You need to pin down something as "absolute" or else you'll drive yourself crazy going in circles.
I use indirect lighting for all my renderings (enjoying my dual-core FX-60) and am able to make up good materials on-the-fly with only a couple of custom saved scenes in my arsenal (so far). I just got a glossy white plastic material to render well--one of the difficult ones.
Other than all that, I don't know of a set library of materials for PhotoWorks. Maybe do a serch for Mental Ray materials (PhotoWorks rendering engine if I remember correctly).
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Go to http://www.grsites.com/textures/ they have many textures such as wood and marble that can help with your scenes. After downloading a texture you like, on the Material Editor, pick the 1st button on the top-left (Create from File), find your .jpg and create a material.
Then it's a matter of going to the illumination tab of that material and finding the "Material type" that works good, such as Plastic, Anisotropic, and Conductor. I usually do not accept the default settings of the of the material type, meaning I tweak the Ambient, Diffuse, Specular, etc. The next tab is Texture, and this is where you adjust the Map Width and Height.
Again, there really isn't an "Easy Button" (not that I have found anyways).
Flores
SW06 SP4.1
Is it possible to create materials from texture? I do not think we are talking about the same thing.
The materials I am talking about are the ones that are represented by a sphere in the material/texture selection menu of PhotoWorks (check out chrome or Mercury). You can edit them and change the color, the way light reflects upon it, surface style, etc.
The files are found (by default) here:
C:\Program Files\SolidWorks\photoworks\data\Materials
They are .P2M files apparently. I'll keep looking.
Both procedural and textural materials carry the P2M extension. It stands for "PhotoWorks 2 material".
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 5/01/06)
SW 2006 SP 4.0
I hope that now that I am using the proper vocabulary (thanks rockguy!)it is clearer what I need.
Once again, thank all of you guys for your help and patience.
brushed metal1 through brushed metal7, rough cast, etc.
Found also at C:\Program Files\Solidworks 2006\photoworks\data\Materials\Metals\miscellaneous
As for the 3D Sphere materials, I haven't found them anywhere and the ".p2m" comes up as "peer2mail" file on Google.
Flores
SW06 SP4.1
Exactly, thats also the definition on www.filext.com
Oh well, to bad
Thank you all.
The user only has the option to modify the provided
(default) procedural materials using the options in the material editor. Once a procedural material has been modified in the material editor, it of course can be saved as a custom material. This newly saved P2M file can be distributed so others can use it but I'm not sure there is any real value in that (except time) because all users are capable of adjusting the settings to achieve the same result.
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 4.0
Well, now at least I know for sure.
You could submit this to SW as an enhancement request, I have.
Rob Rodriguez CSWP
President: Northern
SW 2006 SP 4.0
If you choose another material type, such as glass or water, you can get all sorts of other options in the Illumination tab. So you can make almost any effect you like with the given materials to start with.
Jeff Mowry
