Mirror-like surface by spraying chrome finish paint
I need to make a mirror-like (shiny) surface by painting some chemical on a transparent plastics (like plexiglass) or a regular glass plate. One side of the plate should be shiny, when looking from the un-painted side(not on the top surface of the painted side). I tried a chrome finish paint which I bought from auto part store, on one side of a glass plate, however, it was dark color, instead of white and shiny, when looking from the un-painted side. The top surface on the sprayed side was shiny. Is there any spray or easy-to-use chemical that gives white and shiny (light reflecting) interface when looking from the un-painted surface?
Thanks. Peter
Thanks. Peter
RE: Mirror-like surface by spraying chrome finish paint
Mike Halloran
Pembroke Pines, FL, USA
No, I cannot use ordinary mirror.
The surface is a part of an optical device. It doesn't have to give mirror-like image, as far as the surface reflects light well. Thanks.
Peter
Red Bank, NJ
Is localized plating or ceramic glazing an option?
