Calculating how much a electric a electromagnet requires
I need to work out how much a power a certain electromagnet requires.
I apologise for my ignorance before i proceed and appreciate any help.
I have the following information:
9 x 1 inch magnet
with an iron-core coil with a current magnetic induction field of approximately 2 Tesla
I specifically want to know how much electrical power such an electromagnet requires in 1 minute of use.
Is this possible to answer with this information?
If not what other information is needed for a possible calculation to be performed?
Thank you for your time.
RE: Calculating how much a electric a electromagnet requires
sorry it has a diametre of 6 and height of 1
What is the amp draw and voltage of your magnet. Assuming DC the power is than V*I. Otherwise you have provided not nearly enough information to answer your question.
Mike
Please correct me if I'm wrong, or maybe I should verify first before answering but I'm not at my desk (ok, I'll have to wing it).
If you have the volume of the solenoid and the generated field level at center, can you calculate the total energy required to obtain the field in that volume. Assuming a single conductor at first and then believing everything is ideal condition. Low carbon steel as core? This may get you in the ball park but with out specifics then it really is just a guess.
As mentioned, E and I values, also Turn value of coil could help in place of E & I. Inductance would be helpful too if Properties of core is not exactly known. Just to say the more you can tell us the closer we can get to the answer.
