open/closed valve spool
I posted this question awhile back in another forum.
I am stumped!
I currently manufacture hydraulic valves. which will operate a certain kind of equipment. I offer either open center valve, or closed center valve.
How can I make One valve to be able to operate on both closed and open center systems?
Presently I am using 2 different valve spools. one for open and one for closed center..
I would like to just make one valve spool that would handle both open and closed center systems..
any help would be greatly appreciated.
thanks,
Brent
I am stumped!
thanks,
Brent
RE: open/closed valve spool
One possibility to achieve what you want would be a Pilot to Close Poppet design like Nachi has, or maybe had, have not looked that one up for awile. It uses 4 poppets and a D03 4-Way Directonal Control to pilot the Poppets.
Using a D03 Directional Control with "P" Blocked, "A" and "B" to "T" Center condition gives an All Ports Open center while the same D03 valve with the spool reversed would give All Ports Blocked center.
The Nachi valve only comes in a D08 or D10 size.
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
http://www.fluidpower1.us
Depending on these features and the cost target, will determine options.
If this is what you are describing, it should be fairly simple. If you mean both options on the same individual spool machined part, I'm with bud-that is a challenge way beyond my knowledge.
k
