Best way to estimate performance of a SLDASM ?
I'm guessing either file size, assy stats, or both give the best idea as to how taxing a SLDASM is going to be on your system; assuming the computer is fairly "balanced" (proc, ram, video).  Any input or corrections on this thinking?  I am sure other factors, I just want to be able to get an idea fairly quickly so wondering which 1 or 2 factors would best represent this.
Mike
RE: Best way to estimate performance of a SLDASM ?
In additional to file size and assembly statistics, the method and complexity of the individual part files will dictate assembly performance.
What are you trying to achieve?
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Yeah, I hear you with respect to the part complexity issue; I am lumping that in with the additional factor of "my past experience" in order to actually take the most meaningful factors and formulate a rough of idea of how long, for example, assy dwgs might take.  That is the essence of what I am trying to achieve.
Of course the process relies on my past experience of what the part complexities will typically be based on the type of assy as well as, in general, what an assy of the type being estimated would involve (in terms of performance affecting characteristics).  I hope that all comes out how I intended.
I know I am not going to have exact quantitative info from this but some idea at least without having to open and look at every assy people are working on.
Thanks for you help on this,
Mike
