static pressure?
static pressure?
static pressure?
hi friends:
what is mean static pressure of fan  and how can i calulate
it?
where is it application?
any articles will be gratefull
best regrds
RE: static pressure?
Static Pressure:
A fan must overcome resistance when pushing air from the discharge of the fan through the duct to some final outlet. This resistance is known as static pressure. Static pressure in a typical duct run is caused by the velocity of the air, type of duct material, elbows/fittings, dampers, diffusers, etc.
Fan static pressure is measured in inches of water gauge
To calculate static pressure, you must the ductwork system configuration. See link for an example on how to calculate static pressure.
http://www.mece.ualberta.ca/courses/mec463/2001w/463_sol08B.pdf#search='calculate%20fan%20static%20pressure'
For more detail, Refer Chapter 35 of ASHRAE Fundamentals 2005.  "Duct Design".
hi friends:
thank u very much for every one help me .
best regards
