Looking for a special DIN rail mount!
Here's a wierd question/problem.  I have several pieces of DIN rail mount equipment in my system.
There is an absolutely great DIN rail mount on a Compumotor controller that I have.  It is an aluminum extrusion with a spring wire clip.  The mount holds it so it will not slide along the DIN rail, which is very nice for my particular application.
I have seen the same mount on a power supply from Phoenix.  I would like to mount some other equipment with these mounts, but I have not found them anywhere.
Can anybody suggest a source for some of these good DIN Rail mounts ????
RE: Looking for a special DIN rail mount!
JJ:
Thier are many companies, but they look for business with OEM's to sell quantity.
I would do a search for 35mm din rail mount(s) with www.google.com
see also http://www.bb-elec.com/productlist.asp?Dept_id=279
B&B have the plastic version for sale...I've used them.
You may also want to check some of the larger DIN companies like phoenix, weidmuller, entrelec, altech, and etc.
Carl
I have found that Phoenix is a big supplier of DIN and accessories
