Restart Analysis
Restart Analysis
Hello everybody,
I'm a new member of this forum.I'm trying to do a restart analysis with Abaqus6.5.1/Explicit :
abaqus job=JobName oldjob=OldJobName
The analysis doesnt't start and in the log file I've found this error message:
***ERROR: ABAQUS Data Storage Manager error
***ERROR: par_Create, Create Partition
***ERROR: Open, Specified partition is open
Thanks in advance for any kind of help you can give me
RE: Restart Analysis
Never seen that error before, I would hazard a guess that it is some sort of I/O error (?).
I would check that you have the restart file from the initial analysis in the same directory as the restarted analysis.
Also, ABAQUS doesn't seem to like spaces in filepaths.
Martin
thanks for your response.Restart files (.res, .stt, .pac, etc)
are in the same directory of the restart analysis and there aren't spaces in filepaths.
I've checked the restart files and I've noticed that the .pac has a huge size (1,4GB). A friend of mine said that it could be the problem. Is it possible? Anyway, to minimize restart files size I've used the overlay option for the previous analysis:
*RESTART,WRITE,OVERLAY
but it doesn't work. If you have some tip I'll be very grateful.
Thanks again for your advices.
Andrea
Other than that, I would be tempted to contact ABAQUS, as this seems like something they should know about.
Martin
