Current sensing circuit problem
I went over thiis plan in detail with an Analog Device engineer, and it appears I have the exact same schematic, but somehow this isn't working:
link 1 is my schematic, link 2 is the AD drawing.
http://melrosemagazineonline.com/ad628schem.jpg
http://melrosemagazineonline.com/ad628.gif
This concept was ok when I was using a BB2604 (audio op amp) in the same manner. I could get that older version to output a volt or so which was proprotional to the voltage drop across the shunt.
Now with the AD device, there is still a volt dropping across the shunt, but no change on the output of this new "fancy" IC I decided to use instead. The output is sitting a 7.84 volts , and drops maybe .02 when I strain the motor. It should be going up not down.
I tried a diffrent IC but no change.
Any suggestions on what went wrong?
Todd Chapman
Todd Chapman
RE: Current sensing circuit problem
You have checked your wiring right? (Where I botch it up).
Weird scuzmatic on the motor.. I don't understand it. Does it go to ground somewhere.
You get what when you short R4?
Short R1 see what you get.
Keith Cress
Shorting the 1.2 ohm shunt resitor gives the same output!
Shorting R1 gives 23 volts. Pin 1 is the 24v supply. Pin 8 is off the motor side of the shunt, and is dropping from 23.85 down to 22.4 when a heavy load is on the motor.
The output pin five with the current gain set is putting out 7.88, and DROPS .02 to 7.86 on a heavy load. This is not right as it should go up, which would make it seem the inputs are reversed rights?
I pulled out the fileter cap just to check but ne change. I changed R1 to 15k, it just dropped the output to 1.7 volts, with still only the -.01 change on a load.
Makes no sense. I pulled the comparator out too just to make sure it wasn't screwy.
I'll call them tomorrow and see whats up. I let this one slip putting an unfamiliar ic on these new boards without breadboarding first...
Keith Cress
I think that you have guessed the problem in that the common mode input voltages do not incluce voltages near the negative rail.
Worked it out with AD that Vref has to be a posotive voltage. I had it at ground for both the pin 3 and off the Rext2 location as well. Nice working chip, programmable gain plus a filter.
Thanks for the tips.
