I need some detail of shunt trip mechanism
I know shunt trip using the magnetic field of an energized coil to trip circuit breaker.  But how do I know the minimum current through the coil which would have strong enough magentic field to trip a 20 amps CB?
Thank you! I am new to this place.  Hope can get your help!
RE: I need some detail of shunt trip mechanism
From http://www.ch.cutler-hammer.com/
"The Shunt Trip provides remote controlled tripping of the circuit breaker. The shunt trip consists of an intermittent rated solenoid with a tripping plunger and a cutoff switch assembled to a plug-in module."
Thank you, Busbar!
Does this mean shunt trip rating has nothing to do with circuit breaker rating?  It actually trip CB by mechanical means?
Yes the shunt trip generally requires a separate source of control power.  You need to specify the operating voltage when you buy the shunt trip.
