convert tube to sheetmetal?
is it possible to convert a tube to sheetmetal? basically the shop wants some paterns they can attatch to the pipes to aid creation of discharge heads (pumps). so im thinking sheetmetal is the way to go. i've created the part but cant any of the sheetmetal commands.
also is it possible for the interference check to place semi-perminate lines to show where i need to cut? they wanted me to do this too but wasn't so sure it could.
RE: convert tube to sheetmetal?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-05)
Create your sketch, then extrude within the sheetmetal commands.
Chris
AutoCAD 06
However, if you just want a cutting line pattern, you can leave the pipe as it is and create a sheet metal part using the outside surface of the pipe:-
1) Select the outside surface & do an Offset Surface of zero.
2) In the Solid Bodies section, delete the pipe body.
3) Thicken the surface to whatever thickness of material you want to use for the pattern ... make sure the Merge option is NOT selected.
4) Create a small slit down the length of the thickened surface.
5) Select the Insert Bends icon then select an inside edge of the slit.
6) The thickened surface should now be regarded as an SM part & should be able to be flattened to create the cutting pattern.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
