Adding Dimension to Assembly View in Drawings
Hi:
I've been looking for a way to do this for a few days, but I've yet to find or understand how it's done.
 http://img19.imagevenue.com/img.php?loc=loc105&image=17650_tseriesAssm.JPG
http://img152.imagevenue.com/img.php?loc=loc247&image=17656_tseriesDraw.JPG
As you can see, I've posted to pic.  One of the Assembly and one of the drawing.  Both are made completely from scratch through a program I have been writing.  Basically, I make all parts and import into new assembly.  Parts and Assembly are saved in a specific folder.  I've finally completed the assembly(very tired), but have run into some real issues when trying to create drawings.
I've created a new drawing and inserted plus rotated a new view of the assembly.  I am having alot of trouble trying to place new Dimensions driven off of specific edges.  btw, dims on drawing are manually placed.
What I was really asking was if I can pick certain edges or features and create dimensions and place them certain distances away from starting point.  Is there a reference for programming in vb.net other than help?
Also, I was curious if anynoe else is delving this deep into automating SW.  I am having alot of fun making my job obsolete.
John Fourhman
RE: Adding Dimension to Assembly View in Drawings
A standard practice should be to not rotate drawings views for reasons just like this (and others).
Instead, switch to the assembly model and create a Named View. Then Insert a new Model View in your drawing, and choose to use your newly created Named View to be displayed.
Ken
Thx for the help.  That would make it easier to get to where I am now.  I can go and edit my project to incorporate that idea.  Would that help with the current dimension issure I have?  I know I can auto Dimension, but I only want dimensions pulled that I need.  Everything else is just clutter.
