drucker-prager, then frequency extraction?
xerf,
Thank you for all your help. One final question for you if you don't mind, or anyone else. After I run a compaction simulation, is there any way to take the compact and run a frequency extraction so as to compare natural frequencies to the pre-compact?
thanks again,
Chris
thanks again,
Chris
RE: drucker-prager, then frequency extraction?
Module Step ->Create Step
Procedure type: Linear Perturbation
Step Type: Frequency
