SolidWorks 2001 Sketch Disappears
Hello
I hope somebody can help me. When editing or creating a sketch in the sketch plane the sketched features disappear as I move the mouse pointer over the sketch. To be able to view the sketch again I fit the sketch to the screen. Also, if I try to dimension an entity once I pick a feature the entire sketch disappears or it disappears as I move the pointer over the sketch. Somebody please help it is extremely aggravating and difficult to use the software. Any advice would be welcomed and appreciated.
John
RE: SolidWorks 2001 Sketch Disappears
This is a video card issue.  Close any open documents and go to Tools->Options->Performance and check "Use Software OpenGL"
If the above suggestion eliminaes the problem, it proves that your card should be upgraded to a SW recommended one, unless you can live with the lower performance of the "Software OpenGL".
http://www.solidworks.com/pages/services/VideoCardTesting.html
You could also try using a newer driver for the card you have. Sometimes that helps even if the card is not "certified" by SW.
cheers
Helpful SW websites  FAQ559-520
How to get answers to your SW questions  FAQ559-1091
I tried to check the box for "Use Software OpenGL" however it is grayed out.
Close all open Solidworks documents and then set the option for Software OpenGL.  This box is grayed out when any documents are open.
You guys are awesome. It worked. Thank you very much all of you for your help and kindness.
John
You can find all of this usefull information in the FAQ section of this forum.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
