Bevel Gear Model
Bevel Gear Model
Bevel Gear Model
Does anyone have a bevel gear model that they are willing to share which is not from the design library?  I need it to be easily modifiable.
Erik
RE: Bevel Gear Model
You can generate the gear from the SolidWorks library, save it as a copy and then modify the saved copy. Make sure you check the save as copy, this will ensure no damage to the original SolidWorks library part.
Hope This Helps!
