Anyone ever import a CADENCE Allegro PCB into SolidWorks?
Hi Folks,
I'm just wondering if anyone has ever import a PCB design (done in Allegro) directly into SolidWorks. If so what have you found to be the best intermediate format? Or what intermediate formats are available for export within the Allegro environment (e.g. IGES, STEP, etc.).
I've never done anything like this before and am in the dark. Any feedback would be appreciated greatly.
Best regards,
Best regards,
Chris Gervais
Application Engineeer
CADD Edge
RE: Anyone ever import a CADENCE Allegro PCB into SolidWorks?
I create gerbers from the Allegro file and then convert these gerbers to dxf (Allegro can output dxf's, but I use a package called ExcelCam when I get gerber sets to bring in each gerber layer and exprot them as dxf). Import the layers you need. The silkscreen layer is probably the most important with all the designators. I will import the soldermask layers, pastemask, the drill holes, and the outline. I will then take all the data sheets on the major components (connectors, switches, large caps, chips, screens....etc and create these parts. Or check 3d content central or contact the manufacturers for 3d models. Use all this to build up your PCB assembly using the silkscreen to locate the parts.
Sometimes I start the PCB in SW to place major components and get an idea of the size and then exprot the PCB and the footprints out of a drawing as a dxf.
RFUS
Chris Gervais
CADD Edge
You export the Allegro data as an IDF file (there are actually two files) and then use CircuitWorks to import the data into SolidWorks which builds a 3D model of the board.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
http:
