Corrosion on laminated seat of butterfly valve
We have been experiencing some failures in a sea water system of some triple offset hard metal seated laminated butterfly valves, the laminate is described as ASTM A479 type 316 Ti/Graphite and you can see various layers.
We know we have had some failures of rubberlined butterfly valves upstream and it apears that some iron oxide (brown rusty powder) is sticking into particular layers of the laminate, and has started some kind of corrosion.The rest of the valve looks new.
My question is can the carbon steel contaminant in the system cause corrosion on the stainless parts of the laminate, and if so how do we get out all this contamination to stop the failures continuing to happen. Apologies I have no lab analysis as the guys through the seat away when they replaced it.
RE: Corrosion on laminated seat of butterfly valve
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
