TEXT COLOR
TEXT COLOR
TEXT COLOR
I need a tip: when I run a draft analysis on a part I move the cursor on a surface and it shows the draft angle next to the cursor. The only problem is that the color of the text (draft angle reading) is a light green color which is barely legible. I would like to change the color to black. I've checked the help menu and this forum but no luck. Any tips are appreciated.
Thanks.
SW '06
SP 3.4
Dell 380
nVidia FX1400
Win Xp sp 2
RE: TEXT COLOR
You should be able to change that in your system options>colors>dynamic highlights.
RE: TEXT COLOR
But what he is talking about is the draft analysis reading. There are 3 colors and that green is 1 of the 3. That color I don't think you can change. What color is your background? That might make a difference on how that color is seen.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: TEXT COLOR
Thanks 'automationbabe' but that's not it.
Scott, I use a gradient background with the following custom colors:
 top gradient: hue - 33,sat - 80, lum - 182, red - 214, green - 207, blue - 173
 bottom gradient: hue - 40, sat - 43, lum - 211, red - 230, green - 230, blue - 219
I didn't have this nuisance with SW '05
Thanks for the help.
RE: TEXT COLOR
Well what I have found out is that if when you are in the command of the Draft analysis and you get the oppotunity to Edit the color there (feature manager). When you select the color and click "OK" the next time you use the Draft analysis that color will be used.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: TEXT COLOR
I cannot get any text to show up in the graphics area in either SW06 or SW05.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: TEXT COLOR
I appreciate you looking into this Scott. I do hope you can find a solution for us. Thanks very much for your help.
