ASME publication, 82-PET-12 ôBehavior and Wear of Check Valves"
User jdptx in a post on 15 Oct 02 (thread408-32499) referred to an ASME publication, 82-PET-12 titled “Behavior and Wear of Check Valves". This publication addresses pipe diameters and expected wear that occurs as the result of turbulence caused by fittings and other devices. This publication is probably out of print.
I’ve done a pretty good search out there for this document and haven’t been able to locate it. Has anyone seen this document available anywhere online for download or purchase?
Eric Stinnett
www.southernco.com
RE: ASME publication, 82-PET-12 ôBehavior and Wear of Check Valves"
www.asminternational.org
If that doesn't bear fruit I would contact the following. There is a very reasonable fee, usually $15.00
http://www.lindahall.org/
