A paper on Engineering Safety
Hello everyone,
I have been invited to present a paper in a seminar on engineering safety can someone help with some inputs please.
RE: A paper on Engineering Safety
Talk to the audience and not your slides
Don't read your slides
Memorize your slides
TTFN
Do not put up slide after slide of text and simply read what is on the slides.
Airplane wreckage.
Explosions with surround sound.
Blood on the high...
... er, try to make your visuals interesting.
Mike Halloran
Pembroke Pines, FL, USA
Cheers
Greg Locock
In - Out - IN - Out. Repeat.
Drink the water on the dais. Your throat will get dry and you may sound funky.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Still, all relevant....but what the guys may be saying is "give us something more to go on, narrow the field a bit."
JMW
www.ViscoAnalyser.com
What is the focus of the seminar? Who is sponsoring it? What is your area of expertise?
Ed
corus
I know some stress engineers that do that plus the PSF (Personal Safety Factor) - that is normally about 1.5
On one project, the fellow that was cleaning the end bearing caissons had a safety rope approx 100' long secured at the top; the depth of the hole was approx 40'...
Dik
Once you figure in rope stretch, I think that might be a factor of safety of less than 0.4!
That's a definite failure!
I know you're kidding, but I don't think factor of safety really factors in (no pun intended) to rope length in this scenario. Rope strength would though!
Ed
Also, as my thespian mother advised her students, "Speak to the back wall, then you'll never have to think further about effective voice volume for the room size."
