Automotive adhesive solvent
Does anyone know of a solvent that will remove a medallion from a porcelain finish without damaging the surface? The medallion is fixed to the surface using an automotive trim type adhesive.
This is a salvage need so quantities are low.
RE: Automotive adhesive solvent
