Problem with Assembly
Can any help me with this? I have assembled a tube type carrier. The ends of my tubing need to be notched with a .375" end so that they butt up against each other perfectly. Is there any way to trim a solid to another solid after it is assembled?
RE: Problem with Assembly
You might try the Weldment feature. Basically you create the tube layout in the part by using 3d sketches to create the path. Then you can easily trim the corners where they meet.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
