Surface finishes from glass bead abrasive blasting
Does anyone have a chart, graph, or something that provides surface finishes (in rms microinches) vs pressure, time, and bead diameter for abrasive glass bead blasters (e.g. for a TRINITON 36/BP2)? Does the model and manufacturer of the machine matter?
I'm a design engineer and would prefer to call out a surface finish over calling out a process on our drawings (we're trying to stick to defining the end-item and trying to avoid specific processes).
One of our suppliers said his TRINITON 36/BP2 provides 8-16rms to AL6061-T6 using .005 beads at 25psi but he didn't say how long it takes. Would there be much difference between values for 6061-T6 and, say, aircraft grade titanium?
Lastly, our QA department wants to know if there is there an easy way to measure rms surface finish. Any recommendation?
Thanks in advance!
Thanks in advance!
Tunalover
RE: Surface finishes from glass bead abrasive blasting
