ERROR... Unable to determine file system info; 0 -1
I have recently been trying to use the MSC Nastran/Patran on my PC and have encountered the error
"ERROR... Unable to determine file system info; 0 -1"
Any ideas what it means ?
RE: ERROR... Unable to determine file system info; 0 -1
I recomment using NTFS.
PS Thanks
Before doing all that, does the problem appear when you run patran or when you run nastran? and when exactly when you run them.
In case it's patran, I recomment checking the properties of the link (shortcut) you are using to run it, and the working directory specified in the shortcut.
Thanks for the responses - sorry I havent returned your comments - I have been distracted onto other things for a while. Anyhow, I will be trying to get this working again this week and any help would be greatly appreciated.
