standard for testing grinding wheel
Which standard or procedure cover the testing for grinding wheel at the manufacturer plant , before sending it to the customer use.
I know that a test it is to run it at 150% the surface speed for a while, but I do not have a standard to follow.
Thanks in advance
Thanks in advance
RE: standard for testing grinding wheel
You might also check the different manufacturer's web sites for a reference.
